Post new topic Reply to topic  [ 3 posts ]
 Post subject: Chamber 17
PostPosted: Mon Aug 01, 2005 8:47 am
[b]Afterwards[/b]
I've set loose the guards that
stand before my door.
I've let cells collide in suicide
until they take me.
If there were stories left to tell
I would hear them.
Behind the waterfalls of channeled panic
spilling their prideful progeny
I can stay hidden in the noise.
Being invisible has its cameo rewards.
It also keeps visible the durable lifeform
murmuring beneath the wickedness.
This is truly the only creature I care to know,
with luminous ways of sweet generosity that suffers
in the untelling universe
of the unlistening ear.
When I am found out - after I am gone -
by a stranger's heart whose drill bit
is not dulled by impersonation,
I will open eyes, peel away skin,
awaken the heart's coma.
I will set aside the costumed figure
and redress the host
so its image can be seen in mirrors
I set forth with words bugged by God.
When these words are spoken,
another ear is listening on the other side
beaming understanding
like lasers their neutral light.
The common grave of courage holds us all
in the portal of singularity,
the God-trail of rebeginning.
Somehow, so seldom, words and images
thrust their meaning into heaven and conquer time.
But when they do,
they become the abracadabra
of the sacred moment.
The pantomime of the public's deepest longing.
Afterwards,
the improbable eyelid glances open,
the skin folds away,
and the heroic eye awakens and remains alert.
Afterwards, the words eat the flesh and leave behind
the indigestible bitterness.
The emotional corpse shed,
an insoluble loneliness.
The cast of separation.
[bewerken aan 25-8-2005 door CV]
My presence is the portrait
of the original you.
 Post subject:
PostPosted: Mon Aug 01, 2005 4:08 pm
beautiful isn't it...I assume you are opening this poem for discussion...
I can not expess in my word...the thoughts that these words project in my mind...I can only stand speachless in awe....that so many emotions could be put in words.
nothing I could say, would convey their meaning to me...which I find very personal...any better.
the most I could possibly say is...ahhhh yes.
 Post subject:
PostPosted: Tue Aug 02, 2005 8:14 pm
I ran across some thoughts of Dr N... concerning the poetry... and feel it is important for our understanding... this is not just "poetry"... as you may discern... and this validates the interconnection between the Philos, the paintings and the Art...
[quote]Sarah: "That's interesting. Everything else -- the paintings, music, artifacts, and philosophy -- is placed one-per-chamber. Why do you suppose they've placed two poems in each chamber instead of one?"
Dr. Neruda: "In my opinion it was to provide a broader perspective into the particular theme represented by a specific chamber. The poetry appears to be designed in such a way to provide both a personal and universal perspective in each of the chambers--but again, it's just a working hypothesis at this time."
Sarah: "I assume from the examples you left me, that the poetry is also a bit less abstract when compared to their philosophy and paintings. Have you considered how the poetry is related to the paintings?"
Dr. Neruda: "Yes. And I believe the poetry and the paintings have the strongest connection of all the objects in each of the chambers. I think the paintings illustrate -- in some subtle way -- the themes represented in the poetry. In some instances, when the painting represents an assemblage of abstract objects, the poetry is also more abstract. When the painting is more illustrative, the poetry seems more like prose."
Sarah: Are you saying then that the poetry carries the central meaning of each chamber?"
Dr. Neruda: "I'm not sure, but it does seem that the poetry is somehow implied symbolically in the chamber painting that it's associated with. The problem is that the poetry is so highly interpretive that it's impossible to know precisely what its theme is intended to be. Also, and I should have mentioned this before, but the grammar and syntax of their language is very different from ours in that they have no end to their language punctuated with periods.
"In other words, if we made a literal translation, there would be no sentence structure--more like a logic syntactical approach--which simply means an abstracted language flow which would be, for most people, very difficult to understand. When I was doing the translations of the poetry, I placed it in a sentence structure that fragmented its meaning so that it could be better understood. Perhaps in the process I unintentionally changed the meaning, but it was either that or the poetry would be too abstracted to understand."[/quote]
http://www.wingmakers.com/neruda2.html
