Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
 Post subject: Re: Elimination of hard currency...
PostPosted: Thu Apr 22, 2010 9:58 pm
money is the root of all evil
it makes you feel unbelievable
http://www.youtube.com/watch?v=Ma9Qng5uubUble
BREATHE IN LOVE
BREATHE OUT FORGIVENESS
(If you’re not in your breath, you’re in your mind)
 Post subject: Re:
PostPosted: Thu Apr 22, 2010 10:07 pm
Solaris wrote:
Problems cannot be solved by the same level of thinking that created them.
-Einstein
We have the people who create most of the current world problems proposing a solution... how ironic!
Einstein`s approach to solving big problems was to open up to new ways of thinking, redefine original ideas about every problems, and continually consider alternates.
This mental process is not rocket science! It is simply paying attention and learning when to change the way you think. An open mind can better appreciate and recognize new information and new ideas.
- It`s also being aware that new questions can change the way you respond and resolve any problem. Here are five easy to remember mental guidelines to help you shift and keep your mental gears moving:
Nurture in yourself an ability to see and consider contradictory or impossible ideas.
Develop an awareness about being too attached to your own ideas.
Suspect "the ONE right answer," especially if it`s your only answer.
Decide what to do from your best choice between several right answers.
Consciously look for alternatives.
Dr. Edward De Bono, renowned creativity specialist, suggests, "If only two possibilities are evident, choose the third!" This approach will cost you some time.
- It does require extra time to be flexible enough to find, evaluate and integrate other alternatives.
- Flexible thinking improves the likelihood that a change in your consciousness can occur.
- Rarely is everything so urgent that no time to think is possible.
- Often the criteria that defines a worthy problem needs to be challenged.
- How much of your work is really mission critical, long term and strategic?
- Can you take time to think and then act accordingly?
Einstein was impervious to most of our everyday dilemmas. He dealt with extra-personal, BIG problems, like "Simplifying the Universe."
- Since the rest of us have to deal with this universe, here are four more proven ways to help you challenge and change your thinking:
Keep things as simple as possible, but no simpler.
Conserve your mental and physical energy for high priority projects.
Create an environment that welcomes independent thinking from every level.
Set an example for thorough thinking, reflection and overview.
It`s true that Einstein revolutionized concepts about time and space, "The Laws of the Universe are not relative," says Einstein, "Only our perceptions of them are."
- He was able to stretch his perceptions and continue working on a problem for as long as it took, even decades if necessary.
- If your timetable is shorter, you can still learn from his diligence to regularly challenge assumptions.
"My only talent for genius," says Einstein, "is my inquisitiveness."
- What can you regularly do to become a receptive place for good questions; your own and others`. Be slow to take "No," or other easy answers. Einstein`s advice is relevant, "Never let yourself be seduced by any problem, no matter how difficult!"
Article excerpted from The Alessandra Report (April, 1996)
Copyright Arden Bercovitz, Ph.D., CSP. All rights reserved.
I like Einstein and thanx Solaris for reminding us of the secu he was. :wink:
PostPosted: Fri Apr 23, 2010 2:22 am
yes, Dr N must have appreciated him too:
Dr. Neruda: "The choice is not made to be evil or wicked, or to select a life path that is excruciatingly difficult for oneself and others. Nor, in the case of Einstein, did he choose to contribute to humanity's understanding in a way that permitted the creation of nuclear weapons. In the formless consciousness of these individuals -- prior to their most recent incarnations -- they didn't make choices to harm or help humanity. They made choices to experience aspects of this reality membrane that would contribute to their own understanding."
"Einstein worked nearly thirty years trying to prove this with his unification theory, but never found his answers. No one supposedly has. I can only report that the Labyrinth Group -- using its LERM technology -- has discovered this force. And this force possesses an unmistakable consciousness. That is, it is neither chaos nor order. It is both, and flows between the two worlds of chaos and order like a sine wave flows between positive and negative amplitude."
maybe his name is "encoded" - one stone (causing so many ripples)
................Image
PostPosted: Fri Apr 23, 2010 2:28 am
Watched Alex Jones' latest production, featuring the "loose change" pioneers perspective of what, just exactly, is going on with $$$ it is called "Invisible Empire" and not too repititious due to all the changes we are going through, it did a good job of keeping in the NOW
It's on You Tube now (in 14 segments) - two hours that you may get your family to sit down and watch if you buy a pizza :lol:
you can find all the links here:http://www.youtube.com/results?search_query=invisible+empire+full+movie&aq=1
PostPosted: Tue May 25, 2010 1:43 am
Got my pizza. :lol:
PostPosted: Wed May 26, 2010 1:51 am
Canadian Silver Maples are still affordable for most and a great investment for the future. They are practical and .9999 pure silver one of the the most pure in the world and increasing in value as I speak, but, still affordable for most. I'm not talking stocks or anything as nebulous as that, the coins are quite beautiful. :wink:
PostPosted: Wed May 26, 2010 5:29 pm
Skills will always be needed.......just the payments for services rendered shall be different.....no need to save anything.......but yourself.....everything to be ....if you are also.......free.
PostPosted: Wed May 26, 2010 9:37 pm
Silver is quite the commodity for those who understand this. Many utilize it for various things such as computers, electronics,commerce, and especially medicine before big pharma began all the lies and deception about naturally congruent things for preventive medicine and healing the body . They especially feel threatened by the multi purposes of silver right now This is for those who know that to help others who don't know what you know, you have to work within their acceptability range and then step by step show them more beyond it...if they ask that is.
PostPosted: Sun May 30, 2010 6:07 am
WOW I LOVE THIS!!! This happened to me some years ago! When the CD first came out I was walking country roads singing this to myself as I listened to it . In such a short amount of time so much has changed....and for the better...for some... :wink:
PostPosted: Wed Jun 30, 2010 7:28 am
Thanks for the "Loose Change" tip...I'm sure it will be a fascinating video.
I put all of my money into gold and silver awhile back. The "money guy" that
I know first told me to do this a number of years ago...he was an intereseting
guy. He used to be a V.P. for the HKSB in NYC, he talked to angels, and he
was "bugged". I can remember riding in his car and my sister called me on my
cell phone. As I was almost home, I said I would call her back and when I did
we were being "bugged" too...just because she called me while I was in his car.
No one casts your image, but you...
PostPosted: Wed Jun 30, 2010 11:28 am
:wink: Anytime Aspirant. :D
PostPosted: Wed Jun 30, 2010 1:12 pm
well, I also heeded (with some reluctance) that inspiration to protect my ass-etts, and traded my paper for PMs... and beefed up my "digital money" by putting it someplace where it accrued interest at a higher rate than the percentage of devaluation of the USD ... but I could still get at it, without penalty or a waiting period, if need be.
Before I did this, however, I bought a water filter, a solar generator and stored enough food to last until a crop came in in the portable greenhouse I also bought, with Heirloom seed ... these things are worth the energy it would take to transport them if we were forced to leave everything else behind... IMO.
I really don't see being displaced, since I don't live anywhere near the Gulf coast, but I understand that a mass migration of those living on or near the coast, would dwarf Katrina, and we experienced $4 gas as a result of that three day event... no telling what would result in 40 to 50 million people being permanently displaced until it is safe to go back there... but the loss of revenues being generated in these southern states, and by even self-employed persons will no doubt effect our economic infrastructure drastically... if not crash it completely.
we had our warning ... our wake up call was Katrina ... we are all in this together.
