Post new topic Reply to topic  [ 19 posts ]
 Post subject: Vibrations of Coherence
PostPosted: Sun May 03, 2009 2:33 pm
The power of the group goes up much faster than the number of people. I’ve said elsewhere it can be compared to a laser. Ordinary light is called “incoherent,” which means that it is going in all sorts of directions, and the light waves are not in phase with each other so they don’t build up. But a laser produces a very intense beam which is coherent. The light waves build up strength because they are all going in the same direction.
Now, you could say that our ordinary thought in society is incoherent. It is going in all sorts of directions, with thoughts conflicting and canceling each other out. But if people were to think together in a coherent way, it would have tremendous power.
—DAVID BOHM
All that is existent in our universe is in motion—an intricate, interwoven web of vibrating energy, rising from the sub-quantum, high frequency levels to don the fabric of spacetime and wear the persona of matter. Whatever the mask, it remains energy, a vibration in dynamic motion, veering off in non-linear, fractal, holographic trajectories that remain un-plotted by our finest minds.
Here, each of us exists as a vibratory field connected to the One Field in which we dwell permanently. We are awakening to the simple fact that we exist as One Being with an infinite sensory perception and intelligence, and yet, we remain sovereign and unique within this meshwork of personalities. This uniqueness is found in our vibration just as our Oneness is found in the vibration, the tone of equality, the Symphony of Source.
EVT 3: Temple of Spiritual Activism is focused on the activation of our vibration as a source of coherent energy, emanating from our Spiritual Center and quantum community, and flowing amid the greater vibratory fields that interpenetrate all living forms in all spacetime. It is playing in a new field of consciousness—consciously.
You can think of the master field of vibration, which encompasses all vibratory expressions from the living to the non-living domains, as the coherence meshwork that unites all life in a single domain of expression, and this expression is the highest intelligence we normally confer to First Source, God, or Creator.
We are actually lifting our gaze to this new field and operating from this domain with a tacit, perhaps ill-defined sense of knowledge, but with our intentions in full command of our purpose. In other words, we each hold coherent intentions to become spiritual activists in our personal domains.
Thoughts, feelings, words, actions, and emanations of a more subtle kind, are each vibratory in their true nature. They flow in and around each of us, and it is this vibratory field that activates, co-creates, and transforms our world at its core reality, which then cascades outward to our local universe. If these emanations are coherent, they become powerful as facilitators, guides, and co-creators.
Does it mean that if you are coherent and hold only spiritually-minded thoughts that you will live in perfect health, possess wealth and abundance, and live in peace and harmony with others? This is a fallacy of human nature: To identify with the external results as the marker of success and efficacy of one’s spiritual application.
The human life, with its material expression, is not what we are. We are vibratory fields that coalesce and shape-shift in spacetime to play, love, guide, communicate, co-create, and learn. Whatever becomes of our materiality—our successes, our failures—these are perceptual artifacts of social norms of another time. What counts, what unfolds in vitality and splendor, is our vibratory field. This is our magic, and it always precedes, and indeed, supersedes, the past and future processes of cause and effect.
Our vibratory field can be understood as the essence of our Spiritual Center that diffuses into our local universe, but it is not limited to local space or time. We are emanating our vibratory field through our physical, emotional, mental and spiritual nature, and to the extent these are coherent expressions, our vibratory field is more effective as an activator and facilitator of Oneness across time and space.
This is the result we aspire to. It is not about achieving health, wealth, and happiness in this lifetime, though these are fine qualities to experience. But for those of you who are experiencing less than perfect health, flowing abundance, and utter bliss and happiness, do not fall victim to the attitude that you are somehow “doing it wrong.” Your identity is not material, nor is it bound to only this time and space. You can be a shining example of virtue within yourself, coherent in your expressions, living from the heart with utter beauty, and yet your health can fail you, your money can flow into scarcity, or your happiness can fall prey to misery.
Are these permanent conditions? Do they prevail over you? Do they control you? No!
You are a vibratory field of energy living within the One Field that is eternal, free, united, and equal to all.
All material things are like wave forms with crests and valleys. Our human instrument is not a stable field that holds a position. We are dynamic and we are always moving with the life energy that animates us, and these movements, in spacetime, intermingle with higher and lower frequencies. They shift and fluctuate. There is a rhythm in the modulation, and when we are in the midst of the lower frequencies, we know it will soon change to the higher, and vice versa. These rhythms are fractal or harmonic in nature in both space and time.
The field of vibration that emanates from your Spiritual Center is not subject to the waveform encoding of our material domains. Its experience is pure intelligence unfettered by modulations in duality. This Presence is reaching out as you reach in, and through this process a new realization is born.
This realization will largely unfold from coherence between your inner and outer domains. In other words, your expressions of the human instrument become aligned to the Presence within you, and you begin to apply this Presence in your daily affairs. I will give but one small example.
Before you drink water, hold the glass or bottle in your hands, and allow your vibration to infuse the water from your entire being (remember, it is not your hands that are the only conduits of your vibration). You don’t need to cling to any particular intention, or impress a thought upon the water, simply infuse your vibration on the water.
Doing something as simple as this is a way to draw your Presence or Spiritual Center into the material domain, or, more precisely, it is a way for you to recognize that your Presence is a facilitator and co-creator within your local universe. You, and everything else around you, are vibratory energy, which is part of the symphony that we call the universe. When you share your vibration consciously to any person, animal, or object, you are instantly more coherent. Your vibrational consciousness emanates with greater potency, and the carrier signal is Oneness.
This is important to understand because as spiritual activists we are not trying to use our vibratory consciousness to make change or intervene in the affairs of our planet. It is simply a dance of vibratory Oneness. It is an exchange of co-creation. It is an intermingling of vibratory facilitation. It is a calling of guidance and insight. It is an observance of unity and its perfection. From these perspectives, the journey to Oneness is summoned through the vibratory equivalent of a bell beckoning each one of us to our shared home.
There will be things to fear in this world, whether it is the elite powers swinging their clubs of greed and power, Earth’s transformations, or the more personal fears of health and abundance. These can become your dark obsession, or your theater of learning. If it is the latter, then you can continue to flow from the inner to the outer realms of matter, aligned to your Spiritual Center and its perspectives. If it is the former, you will constrict this channel and reduce the guidance, facilitation, co-creation, and observance of your Spiritual Center flowing into and through your human instrument.
If you click on the image of the Sovereign Integral (it can be found at http://www.sovereignintegral.org) you will see a diagram that provides a rough approximation of the relationships between the human instrument, its energy centers, the Spiritual Center, and the Sovereign Integral consciousness. This is the scope and presence of our vibratory field.
Reveal this in your interactions with your local universe, not with mere words or actions, but with the coherence of your vibratory field emanating from the perspectives of your Spiritual Center.
From my world to yours,
James
Thank you James.
¡Hola!
¿Cómo está?
Do you like my accent? I love yours! :lol:
THIS.....
.....this is our world.
Thank you for all you bring with you.
I, for one, appreciate it all.
Destiny INsists. :wink:
Russ.....
 Post subject: Re: Vibrations of Coherence
PostPosted: Sun May 03, 2009 9:34 pm
Thanks Russell you're right on top of it. :D
PostPosted: Mon May 04, 2009 12:03 am
WHOOOOT! new materials (downloadable guide) NEW ART! (2 new pics)...another note from James ...
and the 3rd EVTSession... all this and Heaven TOOO :D
Image one and all (I see Ernest's name appears in the guide) for all you contribute to enhance my existence... may I live long enough to return the gift !
PostPosted: Wed May 27, 2009 1:40 am
Newbie
The evt 3 guide itself has a light and airy feeling.
In the ligth of this message from james I would like to mention the work of Masaru Emoto with his message of water and the encoded words used in this evt 3. The words Wholeness and Oneness together with the four perspectives and Source Sync.
Just contemplating the paradigm is activating.
PostPosted: Thu Jan 14, 2010 8:00 pm
VIBRATIONSSSS OF COHERENCEEEEEE :lol: :lol: :lol:
PostPosted: Thu Jan 14, 2010 8:05 pm
IT CAN BE COMPARED TO A LASORRRRRRRRRR :lol: :lol: :lol:
PostPosted: Sun Jan 24, 2010 11:57 pm
I just really really really love the group co-creation and contribution to the realization of the Grand Portal we give in the Event Temples. :D
PostPosted: Sat Feb 06, 2010 12:13 am
Even more....
NOW.
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: Sat Feb 06, 2010 12:03 pm
Am 100 % in accord with that expression .
PostPosted: Sat Feb 06, 2010 12:56 pm
:D
I am also!! It is a feeling experience beyond compare and is making a difference....
PostPosted: Sat Feb 06, 2010 5:01 pm
:wink: Karen.
 Post subject: Vibrations of Coherence ring true.....
PostPosted: Sat Mar 13, 2010 8:00 pm
.....Cogniti.
PostPosted: Mon Apr 05, 2010 4:58 pm
Even more....
NOW.
Earth is passing through one of these corridors of higher dimensional light energy right now, and many of you are aware of this. This is part of your awakening and activation: to know that the earth is on an ascendant path, that this path includes you in a purposeful relationship, and that these new energies will restructure and realign the culture of humanity in profound and positive ways. One of these ways is a new intensity and focus of collective intelligence and empowerment.It is a goal of Lyricus to provide frameworks in which students of its works can empower themselves to be agents of spiritual awakening, align to the earth's ascendancy, and assist earth and the beings upon her in this dimensional transition.
The Rising Heart
PostPosted: Sat Apr 10, 2010 12:17 pm
Until We ALL Rise Up and say No More, No More Will I Be A Part Of This Deception...No More Will I Feed It.
PostPosted: Sat Apr 10, 2010 1:27 pm
Stress is often misunderstood. Many people look at outside events as the source of stress, but, in fact, the experience of stress is actually caused by our emotional reactions to events. A response to stress is experienced as resistance, tension, strain, or frustration and it throws off our mental and emotional equilibrium keeping us out of sync.
And you my dear are quite reactive look at how much at the mercy of your emotions you are and that is because you blame others for your reactions. . You need to get a grip there because no-one here is willing to assume the responsibility you don't think is yours. Call it deception or whatever, it's only you deceiving yourself. :|
Just Chillin :wink:
PostPosted: Sat Nov 20, 2010 11:51 pm
This topic deserves more attention and focus.
PostPosted: Fri Mar 25, 2011 8:12 pm
Yes SI(R).
PostPosted: Sat Mar 26, 2011 8:55 am
Feelings of Unity overpowering....feel the compassion and go with the Flow....is easy to do.....no work at all.
PostPosted: Wed Dec 14, 2011 7:00 pm
Quite.
IT is all about feeling.
http://www.youtube.com/watch?v=olYVnvfPDoI
Actually, I'm keen on living.
Bless you that aren't.
