Post new topic Reply to topic  [ 180 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8
 Post subject: Re: E. CO-CREATE
PostPosted: Mon Jun 06, 2011 3:11 pm
when you first joined the WMF, Watcher its intent was not stated ... you may have believed that it was for your amusement but the one thing we all had in common was the WMMs ... a few years later when the purpose of the forum was stated ... by its "creator" ... some chose to ignore the obvious - that it was the materials found on the website that brought us together .. and their First Point is to restore the Sovereign Integral "state of consciousness"
The First Point of process is the key factor of preparation. If your First Point for the reclamation of the Sovereign Integral state of consciousness is anything less than unconditional oneness, equality and truthfulness in the expression of every moment, then you will hit many walls within the prison, and each time you do, you will be required to start over. Thus, the initial point of self-realization must be aligned to the realization itself. This is due to the mathematical equations that guide the process.
we aren't here to change others ... we are here to change ourselves by using the WMMs ... the "oneness, equality and truthfulness" is not about how we respond to others, it is about how we respond to our SELF ... The WN brings us here, to transform ... how do you respond to that ?
PostPosted: Mon Jun 06, 2011 4:01 pm
By transforming.
In this transformation, you no longer refer to the "WN" as if it is separate from your understand of self. The transformation is in understanding that WH = Self as the integral aspect of all that you are.
The response is thus: Being That.
Likewise 'here' is separate from 'there' and with transformation comes understanding that 'here and there' are Illusion...we are not 'brought here' nor do we 'go there'.
Nor are we guides instructing others. We are able to 'leave a trail' but our focus is on scouting. This is navigating wholeness.
This Focus of understanding brings alignment of individual perception to the WP which is The Reality, where the Chamber of Self is fully activated, and its connection with all 'Chambers of Self' (active and inactive) are realized as Oneness and Wholeness.
Within the connection, the individual realizes the collective is ONE.
Within the connection The Activated respond in accord and assist in the dismantling of the Human Mind System.
In this, the One also contribute to the activation of the inactive 'Chambers of Self'.
One By One.... :)
PostPosted: Fri Jun 10, 2011 10:07 pm
The collective is One.....true but also false at the same time.....very smooth.
PostPosted: Fri Jun 10, 2011 10:25 pm
By transforming.
One By One.... :)
we are all transforming Watcher, but those magnetized by the WN within them, have been given the opportunity to accelerate the process ....
but none of us have actually Transformed ... not even the LTO - which is why they are incarnating(ed) by the millions now, because this is the moment in time, when all the DNA will be activated ... beginning in late September - this final step allows the Entity to fully activate the Source Codes ... and to complete the process that results in a coherent Sovereign Integral state of consciousness.
so yes, we are progressing, but other than the 165 or so James talked about being here now on the same LTO mission to transfer knowledge, who are going to be impacted too .... they are in the same HI as we are ... its DNA is going to be amped up, in some instances 80% and how about Nature? when all its DNA is activated ... it is the "super string" that we are all bound together with .... NO?
DNA is key to the WMMs, it is the thread that stretches from origins to destiny ... it is "the Plan of FS"
(or as Gregg Braden put it scientifically : "God is within us"
You must suspend your belief and disbelief in what you cannot sense, in exchange for your knowing that I am real and live within you. My Central Message.
PostPosted: Sat Jun 11, 2011 11:42 pm
There Is No Thing To Argue
Be Transformed
