Post new topic Reply to topic  [ 4 posts ]
 Post subject: Phase Transition
PostPosted: Fri Nov 23, 2007 1:12 pm
From Hidden Truth, Forbidden Knowledge, by Steven M. Greer M.D.
[quote]
An analogy from quantum physics--a concept called phase transition--is useful here.
If you take a container of helium and cool it down to absolute zero, it begins to boil and agitate very violently. Chaose and disorder increase even as some of the molecules begin to align coherently. At the point that only about one percent--not 99 percent, but about 1 percent--of the molecules within the container become coherently aligned, the entire field, all of the molecules reach a state of coherence--super-fluidity is actually what it is called.
Helium then takes on these magical properties; it behaves very differently and the entire field of molecules is coherent. But just prior to that moment of extraordinary coherence is the point when it is most chaotic and most violent.
We are right now at that phase transition moment in the history of the human race. It is going to get more chaotic and seemingly more disordered. But what we need to see are those [b]islands of coherence and vision[/b]. And when enough of humanity has, a phase transition will happen and [b]the field of human society will quickly transform[/b].
So what is that good future going to look like? Lukily, the Architect has left us a beautiful blueprint, and all of us have that unfolded within us, [b]and we can see it, if we choose to gaze with a steady vision. [/b]
We must learn to be seers, because to the extent we see it and understand, we will be vehicles for manifesting and creating this vision.
[/quote]
This sounds so much like the same concepts in WM and what Event Temples is all about.
Love,
Kimberlee
 Post subject:
PostPosted: Sat Nov 24, 2007 1:14 am
Critical mass and morphogenetic field also come into mind which may explain the phrase,"in but a moment or the twinkling of an eye" , much can change.;)
 Post subject: Re: Phase Transition
PostPosted: Sun Nov 25, 2007 10:21 pm
honestly, I don't know if this is topic related, but i found it fascinating...
http://www.vortexpluswater.com/vortex_basics.htm
PostPosted: Tue Nov 27, 2007 3:33 am
Wow Starduster what a fantastic website! Thanks! I think that what is being discussed here is about the chaos theory. Or maybe my version of it anyway. :) In Kimberlee's transitional phase theory, and the 100th Monkey, critical mass, morphogenic field theory and the Vortex info, what all of them have in common is change, chaos, and a new order out of the chaos. A vortex by the nature of its movement changes whatever is in its path or what is drawn into it. It will transition into another phase. Even in the morphogenetic field reaching a critical mass point, when that point is reached there is chaos in the old order as it transitions into the new. We may not be able to see all that takes place , however you know it takes place for the change you see as a result of it afterwards. Does this make sense? :!:
