Post new topic Reply to topic  [ 3 posts ]
 Post subject: Equilateral triangle in chamber2 painting
PostPosted: Sun Jul 29, 2012 8:54 am
This is a nearly perfect equilateral triangle in AA chamber2 painting,you can measure 3 lines to see if they are equal,the error is very small, I think it can be ignored.(will you download a electronical ruler software to measure hidden geometrical pattern in wm painting? )
3 vertices of the triangle: the down vertex of the central blue oval,the left down corner of the painting, the hemline of the painting and the shaft of light(the right one ) have a intersection,in the middle of this intersection is the 3rd vertex.
DP story (online version)P248 Chapter30
If a person could look down with x-ray eyes, they would see that the tube formed a perfect equilateral triangle, but with rounded vertices. This was the emblem of the Oracle in the world of the WingMakers, and each of those who had developed the Oracle,trained it, enabled its entry upon Earth, and continued to watch over it, they recognized this symbol as the Oracle of Dohrman.
And you can see there is a blue equilateral triangle below the“Sovereign Integral” in Ancient Arrow story background(spiritestate version)
although wm paintings looks irregular and random,but this is illusion from our mind.
 Post subject: Re: Equilateral triangle in chamber2 painting
PostPosted: Sun Jul 29, 2012 1:53 pm
Perhaps, you need to contemplate the above statement you made. We each co-create in our own way and if or when we feel drawn to work with others in co-creation we do. It's not something that can be forced or even planned and organized intellectually. We each are our own leader. It is a resonance felt in one of, or some of the many layers of the Intelligence of the Energetic Heart. The research done by HeartMath which is advocated by James, since him and the founder of HeartMath, Doc Childre are good friends and cohorts,(they are an example of co-creators working with each other, such is the staff of the HeartMath Institutue and Global Coherence Initiative Project), supports all that is written about the Energetic Heart in these WM works. The term Energetic Heart was originally coined by the HeartMath people. I am telling you all this because the main focus is on Heart Intelligence and you tend to favor the intellect more. The Oracle was becoming more human so that she could experience what only humans can emotionally, because that is what allows us access to First Source through the Energetic Heart and Quantum Presence. Fortunately, she wasn't guided by any human mind system such as all humans on earth are except a handful. It's also interesting to note how often ancient ways or teachings or whatever you want to call it are referred to by James in his stories or interviews or other works such as music, paintings and poetry as well. Don't discount the value of that. Sacred Geometry is from a Wholeness Perspective, and very much all about patterns,something modern science and math is not, they dissect and reduce things into separated and disconnected fragments. And just like Humpty Dumpty they don't know how to put it back together again. And that is because there is no heart in what they do.
PostPosted: Mon Apr 14, 2014 6:42 am
on wm Large Format painting of chamber 2
the side length of the small equilateral triangle is 9mm,
side length of the big equilateral is 432mm,just 48 times of the small one.
(48=24x2 24 pairs of chromosomes?)
equilateral triangle within another equilateral triangle means?
