Post new topic Reply to topic  [ 2 posts ]
 Post subject: Our Grand universe (a beautiful pic)
PostPosted: Sun Dec 19, 2010 8:46 am
the pic below is from urantia,7 universes and 1 central universe ,just as wm depicted our grand universe.
the symble of urantia is down,middle 3 circles ,just like chamber 18,and centric circles are so much in wm paintings.
 Post subject: Re: Our Grand universe (a beautiful pic)
PostPosted: Sun Dec 19, 2010 12:48 pm
Question 23 -- There are several references within The Urantia Book that seem to be corroborated by the WingMakers' material. An example is the planetary reference number of earth. Also, the cosmological structure as depicted in The Urantia Book seems similar in some respects to the WingMakers. How does The Urantia Book factor into the WingMakers materials?
The Urantia Book is a Tributary Zone. It is not associated with one of the seven Tributary Zones because these are encoded sensory data streams, and The Urantia Book is pure text without encoding. Nonetheless, it's part of the collection of Tributary Zones for stage two as talked about in question 17.
The Urantia Book is most closely aligned with Lyricus' cosmological sciences discipline, but it was not written or composed by Lyricus. It derives mostly from interdimensional sources -- the equivalent of an earth-based teaching organization, only from a different planetary system. Sometimes planetary systems will exchange important writings or revelatory works for the purpose of circulating philosophical ideas or important revelations. This work is such an example.
http://www.wingmakers.com/jamesqa2.html
this, is not to say that the picture isn't beautiful or doesn't accurately represents the Universe of Universes as well as the Central Universe ... only to make you aware of the origins of the Urantia book, which was not used by the LTO when they composed the WMMs ... presented here in hope that you keep in mind that the Truth is the truth, no matter where you find it ... in fact if your mind is open and your desire is sincere, when you seek FS in every manifestation of life, you will find it saturates everything :D
Observance of Source in All Things is the principle that all manifestations of life convey an expression of First Source. It does not matter how far the unifying energy has been distorted or perverted; the Source can be observed. It is the action of perceiving the unification of energy even when the outward manifestations appear random, distorted, unrelated, or chaotic.
Users browsing this forum: Majestic-12 [Bot] and 1 guest
